Blank V-Ray frame buffer (V-ray for rhino 7)
  • Blank V-Ray frame buffer (V-ray for rhino 7)
    I have a strange problem...
    I use V-Ray for Rhino 7 on a Dell XPS 15 laptop. Recently when I've tried to render, the asset editor says it is rendering but I can see on another window it is 'rendering out' but as a white blank screen, and if I try to click on it, nothing shows (the v-ray buffer screen). The lighting is correct and nothing is blocking the camera. However, when I plug my laptop into a monitor, it renders fine, which makes me think there's something wrong with the display(s) settings, but I haven't figured out how to fix this. Any advice would be great thanks.
    Dear lucy_ayres​ - welcome to Chaos Forums!
    The described does not sound related to Cloud rendering, that's why I will move this thread to V-Ray for Rhino :: Issues section.
    Please define is the white blank screen shown as a minimized window when you go to Rhino icon on Windows Taskbar or not?
    If that is so, right-clicking over it and choosing Maximize will open for you the V-Ray Frame Buffer.
    Just sharing how it sounds like after reading your explanation.
    Please share with us some extra details in order to be more helpful:
    • exact V-Ray for Rhino version (screenshot from V-Ray > Help > About V-Ray)
    • screenshots/video showing the issue
    • how often does it happen
    Waiting for your answer.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support (AEC,HOU,C4D) Team Lead | contact us
      Hi, thanks for your reply.
      The white screen is shown as a minimized window when I go on the Rhino icon. This happens every time I try and render (without my monitor). I tried this with a very simple model, please see the pictures below:
ID:	1208715 Click image for larger version
      This is the current V-Ray version I have for Rhino (up to date):
Name:	Screenshot 2024-05-20 094601.png
      Thanks,
      Lucy
        Thank you!
        Please try the already described steps:
        1. Go to the minimized window
        2. Right-click over it and choose Maximize
        Do you now see the V-Ray Frame Buffer with the render result?
        And share with us how often does this happen.
          Hi, thank you this seems to be working now - it's just slower than it was before.
          I'll get in touch if the issue returns!
          Thanks so much
            You are welcome.
            Write back if needed, yes - we have met this randomly, that's why I was asking about frequency.
            Enjoy your work now with V-Ray!
