WIP Interior Stairs
  • WIP Interior Stairs
    http://www.resolutiondigital.co.uk/Vray/stair01.jpg
    Comment welcome.
    Resolution Digital
    way too much perspective going on.
      also the ambient lighting seems as bright as the sun or brighter.
      WerT
      www.dvstudios.com.au
        http://www.resolutiondigital.co.uk/Vray/stair02.jpg
        Thanks for the comments. Sometimes you work on a project for to long and you get side tracked. I have switched of the lights and just using the sun to light the scene, looks much better and i chnaged the lens to reduce the perspective.
        Resolution Digital
          Much better. If you want, you can leave the lights on, but keep their intensities in a real world scale, and there should be no problem. The main benefit from a "physically correct" render engine, is that you can simply put in a 50W bulb, and it will have a correct intensity compared to, let's say, the sun.
          A.
          credit for avatar goes here
            This is indeed looking alot better then the first one. I was getting sick when I looked at it because of the perspective
            The only thing I've noticed are the wide grooves between the tiles in the floor. I wouldn't let a small child walk on that floor in fear of having their toes getting stuck...
            www.artbyarjan.com - Online portfolio (temporarily offline)
            @home:
            / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
            / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
            @work:
            / Intel Core2Quad Q9450 @ 2.66Ghz /
            Nvidia Quadro FX 3700 / 8Gb Ram /
            / Vista Bussines x64 /
