update maxscript Populate:Terrain - have source code
  • update maxscript Populate:Terrain - have source code
    I reached out to the author a few days ago and he sent me the source code for Populate:Terrain. Anyone interested in updating it for max 2019?
    I think the problem is that the Normalize_Spl modifier has been replaced. See this forum post:
    https://forums.autodesk.com/t5/3ds-m...7597182#M17464
    This would obviously be release free of charge. Maybe open source, on GitHub? I don't script but will coordinate.
    Thanks,
    Caleb
    That is so odd and I am sorry that it isn't working for you.
    https://youtu.be/9Ui_HVuL32I
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
      OK Bobby, now try it with a decent amount of contour lines and a higher rez, like 100 x 100. Worked in 2018 but hangs in 2019 on my both my computers.
        Oh, I use it all the time on very heavy scenes. In MAX 2018 it wasn’t working good and failed a lot, but no problems in MAX 2019.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          glorybound I've noticed that you are using an old version (1.2) so that might be the reason? I have a newer version ( v1.86 ) (Max 2019.3) and it works on simple cases but as soon as I have multiple shapes inside each other with different hight max will crash with a message that mentions runtime error and Normalize spl.
          it would be great if you could upload your copy so I can test it .eventho the new version has more features I could live without it if I had to.
          Edit: I found a copy for 1.2 and it is still causing a crash in the above-mentioned cases .
          Simply, I love to put pixels together! Sounds easy right : ))
          Sketchbook-1 /Sketchbook-2 / Behance / Facebook
            Thanks,
            Caleb
            I have basic knowledge in Maxscript and I did few scripts for my personal use so I might be able to help here.
            PM please with a link so I can take a look.
              I did upload it, if you look back in the tread where we are discussing the same thing the other day.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Thanks,
                Caleb
                Yes, sign me up. I'll also take a look at the code
                Kind Regards,
                Morne
                  Yes, I've tried it and unfortunately, Max Crashed too ..try the following steps :
                  1-create 2 circles shape lets say 100cm and 50 cm in radius at [0.0.0]
                  2-move the inner circle up in the z-direction 20 cm
                  3-convert one of them to editable spline and attach the other
                  4-use Populate: terrain and max will crash
                    Confirmed
                    https://youtu.be/_WBEWM7B-QA
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Okay, thanks bobby
                      I've found the issue and I've fixed it with the help Caleb .will do proper changelog, comments..etc and post a link here for the update.
                        Any update? I am in need of it
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Hey all, here is the script:
                          https://github.com/mxdsa/populateTerrain
                          Thanks to M.Max for the fix!
                            Awesome! I'll try it today.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                              Unfortunately, I got an error.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
