Remove highlight burn in post?
  • Remove highlight burn in post?
    Hi all
    With linear EXR's, how do you remove the highlight burn in post without making the image look flat? Bringing the burns down for seem to always also loose light that is already below 1.0 and make thinhgs look pale washed out
    Kind Regards,
    Morne
    depends on what software you use, typically with a float image you can isolate a range for example darks, midtones, highlites and just drop that part of the range down (not substantially) but should be enough.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      With photoshop I'm not sure how to isolate only the highlights in a 32bit image. Whatever I do, seems to affect the entire range
      Kind Regards,
      Morne
        I use camera raw and lower highlights. There does seem to be a bug, so you have to convert to 16bit first.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090
        • ​Windows 11 Pro
          going down to 16 prevents other things from working so I want to try and keep 32bit
          Kind Regards,
          Morne
            yeah photoshop kind of sucks with 32 bit images. Try using fusion...
            Dmitry Vinnik
            ShowReel:
              Yes I've been using the free version, but its limited to 4K. I'm busy with a stereo VR so stuck with photoshop. Wonder if Affinity can do 32bit https://affinity.serif.com/en-gb/photo/windows/
              Kind Regards,
              Morne
                Did you try in photoshop / image / adjust / hdr toning / highlite compression
                Dmitry Vinnik
                ShowReel:
                  The problem is that flattens my layers and it doesnt have any settings, just on or off. I need something non destructive
                  Kind Regards,
                  Morne
                    Try Lightroom
                      Hi. Photoshop it´s not the best to work on 32bpc but you can try to do it several ways. I have a tutorial but it´s in Spanish: https://goo.gl/rEcTbb (first part it´s in AE)
                      1. Lower exposure until burned values aren´t and lower gamma correction to increase brighness but you will need to add some LUT or another type of contrast later. PS 32bpc tools are really bad xD
                      2. Merge 2 different exposures using a painted/soft mask.
                      3. Duplicate the project and use the HDR toning to compress dynamic range and paste over the 32bpc (use a painted mask again). You can use smart objects to keep the original 32bpc intact.
                      4. Use a plugin like ArionFX
                      But to be honest, if you really want to work on 32bpc Photoshopo it´s not the software, try Fusion/Nuke/Natron.
                      Best
                      My Spanish tutorial channel: https://www.youtube.com/adanmq
                      Instagram: https://www.instagram.com/3dcollective/
                        Ah thanks Adan will try that
                        But 1st, I forgot I also have Natron so will try that 1st
                        Kind Regards,
                        Morne
                          Which Node in Natron should I be looking at for this?
                          Kind Regards,
                          Morne
                            Select all layers > convert to smart object > apply camera raw filter > play with the options.
                            The result of the Camera Raw Filter is always clamped so you can but don't need to continue working in 32-bit.
                            You can convert your layer to a smart object again > change document bit depth to 8/16 bits per channel.
                            The smart object ensures that the camera raw filter is still applied in 32-bit mode.
                            Everything non-destructive.
                            Daniel
                            Daniel Schmidt - Developer of psd-manager
                              Forget Photoshop
                              Fusion Free is GREAT for up to 4K (beyond 4K if you have the paid version)
                              But,
                              I'M SIMPLY LOVING AFFINITY PHOTO!
                              Awesome LIVE 32bit functionality, all the features you ever wanted, and MORE!
                              Very impressed with it
                              Kind Regards,
                              Morne
