When I Render, Light Cache processing is suddenly slow.
  • When I Render, Light Cache processing is suddenly slow.
    I'm proceeding with a render using vray standalone. Render using RTX render is in progress.
    When proceeding with the render with standalone, the cuts in the first few minutes show the speed at which the render is completed in two to three minutes.
    However, after a few minutes, the process of calculating light cache results in a 10-minute pause in light cache with 98% complete.
    After canceling the Render, when it went back on,
    Some of the previous cuts take two to three minutes, and then the same phenomenon repeats.
    I'm asking you a question because I can't find it no matter how hard
    Scene is a very static scene, so there is no change in heavy data from beginning to end.
    I'd like to attach the scene as well, but... I don't know where to share the scene.
    And this is command in standalone.
    vray -sceneFile="C:\Users\user\Downloads\Send Anywhere (2021-09-02 23-57-22)\RenderTest.vrscene" -imgFile="C:\Users\user\Downloads\Send Anywhere (2021-09-02 23-57-22)\RenderImage\RenderTest.exr" -rtEngine=7 -frames=140-330
    Click image for larger version  Name:	KakaoTalk_20210903_111703807.png Views:	0 Size:	22.4 KB ID:	1123882
    Hey hong_leeseong,
    Best would be to forward us a scene for investigation so we could see what exactly is happening.
    You can forward it via our contact form, just make sure to mention this thread (or my name) in the form subject. Much appreciated!
    Nikoleta Garkova | chaos.com
      OK. Thanks! I'll submit in there with mention your name!!
        Scene looks heavy. So I'll tell you when I finish.
          I send you!
            Thank you hong_leeseong,
            We've received the files and need to test the scene - will let you know if we require additional information.
