Camera path
  • Camera path
    camera path is not supported in the .vrayscene.
    will it be expected in the next version?
    What do you mean by camera path ?
    Animated camera transformation should be working, but you have to export an animated .vrscene file.
    Greetings,
    Vladimir Nedev
      I mean animation via spline path. Exporting the file including the animation loses the camera path.
      TKX.
        This should be working, I believe.
        Can you send me the original .max file and the exported .vrscene file to test ?
        You could strip them down and leave only the camera.
        Greetings,
        Vladimir Nedev
          I sent you an email with the files.
          This is the question:
          1- The camera animation works if the .vrayscene file is opened within Vantage.
          2- Animation does not work if .vrayscene file is imported (place or merge). For this problem, in the presence of a scene with multiple cameras, it is necessary to export the geometries in one scene and import the different cameras.
          The cameras don't work in this way. For this reason, I open the camera file in a new scene and then import the geometry. (I will have to do this for each room). The workflow becomes slow.
            Oh, yes, this is a known issue we plan to fix. It is expected in the current builds.
            Greetings,
            Vladimir Nedev
