the depth of the Z- Depth in Render Elements
  • the depth of the Z- Depth in Render Elements
    Hi, please anyone, how to set the depth of the Z- Depth in Render Elements? I have just a poor white color as the result after rendering.
    Martin
    I have founded out, that it works with the EXR format. Am I right or is is possible to get it also with the PNG format ?
      Yes, you can output the Z-depth element in a PNG file, just select "Separate files" in the render dialog. If you're asking about setting a specific maximum depth value that corresponds to white, this is not supported. The maximum depth is automatically calculated from the size of the scene.
      Nikola Goranov
      Chaos Developer
        Hi, here is a comparison between PNG and EXR:
        Vladimir Krastev | chaos.com
          Ah, yes, PNG and other 8-bit formats have sRGB encoding by default, while EXR is 16-bit and linear.
          Nikola Goranov
          Chaos Developer
