Originally posted by hermit.crab
View Post
And with regards to my above post:
Just tested rendering without an effects channel. (So no denoiser in the render elements and lens effects turned off). Now the toning is saved in the rgb pass! Honestly, this is so infuriating and causing me to spend my weekend working out how to bypass this BS! Solution seems to be to buy a denoiser plugin for DaVinci Resolve....
"Post-process your renders without the need of a separate tool.
V-Ray equips you with a complete set of lighting, shading, and rendering tools—all integrated with 3ds Max. The redesigned V-Ray Frame buffer with light mixing and layered compositing means you only need to use one tool for more than just rendering — no need to go back and forth between different apps."
Might want to remove this text as it seems like a lawsuit in waiting.
