1) For exterior shots, is there an advantage to using a large dome vraylight (over the entire scene) with a HDR over putting that same HDR in the environment slot?
2) With a textured vray dome light, would a simple LDR image create similar effects to using a HDR image, or are the floating brightness values within the HDR image 'multiplied' by the vraylight multiplier value? (so the maximum value of the light could in actual fact be brighter than the multiplier you set for the vraylight)
