3d 360 panoramas for SAMSUNG Gear VR
  • 3LP
    replied
    Being web-based stuff as you said, it's literally just the best way to view any VR stuff, at least on the iPhone (and I search a lot) as well as on desktop. I haven't tried andriod as I don't have any.
    You can easily "free up" the tethering to the net part on a iPhone by using a offline web browser like good reader for only 5$.
    Just need to find a way to get the cube maps working in KRPano (haven't really looked into that yet) but it's working great with stereo 360's, stills and videos.
    Stan
    Leave a comment:
  • NicoC
    replied
    Originally posted by JamesCutler View Post
    Thanks it is much appreciated. A tutorial may be in the works, the whole setup is pretty simple to do though.
    Yup, it doesn't seem complicated, you're right.
    We have a good workflow for "simple" 360 stereoscopic panos for a while now, to display with a smartphone + cardboard (using VR Gallery 3d application for Android). The only boring stuff is to crop manually left and right images from VRay rendering, because VR Gallery 3d doesn't handle side-by-side images natively (apparently). Now I'd like to propose to my boss the same thing, but adding focus hotspots, hence my recent interest with KRPano. Ah, and my bosses has an iPhone ... why ??!!
    About KRPano, the only aspect remaining a bit dark for me is the "web-stuff-browser-blabla" to handle ... I'll have to find some time to dive in that properly
    Anyway, thanks again for your informations.
    Regards.
    Leave a comment:
  • Guest
    Guest replied
    Originally posted by NicoC View Post
    Nice stuff, James !
    And thanks for the article, very interesting. Now you have to do some tutorials :P
    Cheers.
    Leave a comment:
  • NicoC
    replied
    Hi guys,
    Here is one of our test's using Google Cardboard. You can go downstairs by focusing on the arrow behind you. http://wip.mintviz.com/Stereo-image-int-002/tour.html
    Also a small article about VR can be seen here, goes over some of the things we have found whilst researching VR. http://www.workshop.mintviz.com/feat...rtual-reality/
    Nice stuff, James !
    Cheers.
    Leave a comment:
  • NicoC
    replied
    Originally posted by AtlJimK View Post
    Any guidance? VR Player must be down-res'ing the content. Image from my Galaxy-S5. BTW: that is an 8K image.
    We're using VR Gallery 3d here, and it works perfectly !
    The only limitation I found so far is that it doesn't handle side-by-side renderings automatically .. one has to split manually VRay rendered image to get _L and _R images. Apart that, it works perfectly !
    Leave a comment:
  • Guest
    Guest replied
    Hi guys,
    Leave a comment:
  • Neilg
    replied
    That is incredibly bad, it doesnt look anything like that on my s4. It's not normal, I can tell you that much.
    What image format are you using, and have you tried a few different ones?
    Leave a comment:
  • AtlJimK
    replied
    Leave a comment:
  • AtlJimK
    replied
    The original spherical is 8192 and the cubical was 16384. The spherical was the only on that loaded properly and even at 8K is was just as poor in the viewer.
    Leave a comment:
  • Neilg
    replied
    The spherical that you're loading into vr player is presumably significantly higher res than that image? I wouldn't load anything less than 8k wide into it.
    Cardboard and vr player was what i first used to test it but we bought a few s6's and gear vr's now.
    The quality difference is worth it - we have 3 separate VR jobs (and one already delivered) locked into our schedule now that I don't believe we'd have got without the screen quality of the gear VR.
    Leave a comment:
  • AtlJimK
    replied
    Nelig,
    I would like to know a bit more about your VR player workflow. I am testing it as a potential viewer with VR Player and Cardboard. I have attached two renders from Vray Stereoscopic helper at fairly high-res; one spherical and one cube 6:1. The cube was does not work in VR Player regardless of format. The spherical works but the display resolution is horrible. Any ideas?
    Leave a comment:
  • AlexP
    replied
    Also "File app" works as does "File Explorer"
    At least one of those is free.
    Leave a comment:
  • 3LP
    replied
    Ok guys, I found out that nothing out there is better than KRPano, even for iOS.
    So if needed to be offline, the best soft is "goodreader".
    5$, install it and drag and drop the folder in itunes in goodreader.
    You now have krpano offline with stereo and video support if needed
    You're welcome
    Stan
    Leave a comment:
  • 3LP
    replied
    Hey guys,
    Any idea whats the best app to view stereo 360 pano on iOS?
    Any luck to get the cubic renders working with a app in iOS as well?
    Cheers
    Stan
    Leave a comment:
  • h3d
    replied
    So I was able to just drop the Spherical Pano into the ORBX samples folder and I am able to view the image OK. There is a seam that doesn't quite get welded in the wrap but it's a quick option. It is a bit blurry but I am guessing that is because it's not actually a stereo image?
    I am awaiting a Vray 3.2 upgrade to test the 6:1 cube render options.
    Leave a comment:
