Hello I'm trying to rotate an object by overwriting the transform matrix via the "-parameterOverride" parameter and I think I'm doing something wrong with the syntax.
So I have a node in my scene that looks like this:
Now if I try to override the "visibility" for example it works flawlessly by doing this:
-parameterOverride="VRSCENE_base@node_2.visible=0"
But If I want to override the transform matrix, I get an error. I'm using this command:
-parameterOverride="VRSCENE_base@node_2.transform=T ransform(Matrix(Vector(1, 0, 0), Vector(0, 1, 0), Vector(0, 0, 1)), Vector(0, 0, 0))"
and this is the error:
Any Idea what I can do about it? aleksandar.hadzhiev To the rescue!!!
Thank you!
-Robert
Code:
Node VRSCENE_base@node_2 { transform=Transform(Matrix(Vector(1, 0, 0), Vector(0, 1, 0), Vector(0, 0, 1)), Vector(0, 0, 0)); geometry=Mesh_18072159227833634042; material=BeachChair_Wood_TEX@mtl_0; nsamples=1; visible=1; primary_visibility=1; scene_name=ListString( "VRSCENE_base", "scene/VRSCENE_base", "layer/_VRSCENE" ); }
Thank you!
-Robert
