Render > selected object with alpha in front of refractive object disregards alpha
  • Render > selected object with alpha in front of refractive object disregards alpha
    Tricky title, but this object is in front of a glass balustrade and as you can see, the alpha is not calculated.
    Not sure if this is intended or a known issue.
    Not really looking for mask-based workaround suggestions, just raising the issue...
    Click image for larger version  Name:	image.png Views:	0 Size:	84.3 KB ID:	1173903
    Is the balustrade shader's refraction affecting all channels? Maybe attach the scene (simplified) so we can take a look.
      Im finding it really hard to pin down consistently to be honest. I had thought this morning it was only an IPR thing, but the render I attached above proves this untrue.
        Best send the scene so we can take a look.
          Here's a scene.
          Very confusing. If I ensure affect all channels set for both reflection and refraction of the glass, it's fine, but if this is no the case for reflection, weirdness ensues.
          Also the non-black alpha parts seem to render additively each time I re-render (frame not clearing between each render). This is probably 'normal' but it's the reflections that are disregarding the alpha? I'm not sure...
            Originally posted by Pixelcon View Post
            Here's a scene.
            Yes, you should keep both refl/refr as "Affect all channels".
            You can change this behavior through the "Previous render" option (Settings>System>Previous Render). "Clear" will clear the frame between renders.
