configure the console
  • configure the console
    Is it possible to configure the console in blender to see the progress of the render? How?
    Thanks.
    Re: configure the console
    Not possible by now.
    andrei.izrantcev@chaos.com
    Support Request
      That is the python console. Vray is an external program and runs as a separate process. It reports it's information to the system console that launched it, and it reports it's remaining time for rendering, or calculating passes.
      Cory
      Cory Petkovsek
      Corporate Video
        Thanks Cory:
        In windows to double click on the blender link to open simultaneously blender and the ms-dos console.
        I'm in ubuntu and calling blender does not open the console.
        The process is then open the console and call blender.
          Yup. I've used unix for years and never use a windowing system where I clicked on icons. Whenever I work on unix I run everything from the console. Even in a windowing environment, all my operations are console based, which may bring up a window or not. Such a workflow will show you the blender console as you have already found.
          Cory
          Cory Petkovsek
          Corporate Video
            space, you could create a launcher (if you are use some desktop environment) and set there "Application in terminal" which cause to start application in the console.
            You could also write a simple bash-script to start app in xterm like:
            Code:
            #!/bin/bash
            xterm -T Blender -geometry 90x10 -e \"/path/to/blender\"
            Support Request
              Thanks Andrei:
              I've learned something over linux. Simple.
