sphere fade diameter dependent of its empty rotation
  • sphere fade diameter dependent of its empty rotation
    A very strange one. For a shot, I link an empty to my character hips, and I add a sphere fade linked to the empty. I discover that the sphere fade diameter vary when my character rotate... Sometime it can totally disappear.
    Vray blender V2.951
    Vray.exe 2.45
    a simplified file :
    sphere_fade_01.zip
    Procedure :
    open the scene, render.
    Reset empty rotation (alt+R), render.
    I'll try to workaround by not linking with parent, and using position constraint instead.
    This file is missing a lot of lib-linking and no animation for sphere fade, but I'll try a "guess fix" - now we'll export only the position.
    andrei.izrantcev@chaos.com
    Support Request
      I think i've deleted all requested linked libraries. It is normal there is no animation for sphere fade, you can just compare a render with and without reseting rotation on empty.
      JF
        Ok, I've make it an option - now the is a control to "Use Location Only".
        Support Request
          Thanks, but I don't get it. The issue isn't about using rotation or not, it's about rotation affecting sphere fade diameter (with a uniformed scaled object). No?
            When using empty it's draw size in taken into account.
            And if we will use only the location there just will be no scale and/or rotation in the transform matrix - won't this solve the issue?
            But I think I'll also add an option to use scale, so we will use scale + offset.
            Support Request
              hy, i wanted to test the spehere fade effect, but i have a strange effect...
              there is my work :
              Prepass irmap for backgroung (multi-incremental)
              Rendering background with irmap from file.
              rendering monkey with spehre fade : wtf ?
              the link : http://www.youtube.com/watch?v=rvxos...ature=youtu.be
              Infographiste 3D freelance - http://www.arnaud-travert.com/
                because I do not yet mastered the sphere fade effect, I made a prepass irradiance map of the whole scene, and it works fine
