imported UV not rendering properly 2.69
  • imported UV not rendering properly 2.69
    I import Xfrog trees in Blender via the obj format. I set the bitmap mapping to UV and then in 2.68 it renders fine but the same file does not render the leaves in 2.69 although in texture view the UV mapping is clearly showing the mapping. I have included a file with just one leave to keep it small, see the difference between 2.68 and 2.69.
    Importing via other file formats (3ds and fbx) didn't make a difference.
    Works perfectly for me in 2.70, uploaded to nightlies.chaosgroup.com (use your chaosgroup.com login/pass).
    andrei.izrantcev@chaos.com
    Support Request
      Works for me to, thanks.
