Originally posted by logan683
View Post
Vray Lens Effects
Originally posted by JuhaW View PostNo atleast current Blender exporter/standalone version.
bdancer, can we request this? Thank you for all you do.Logan
Omnia Mutantur
logan683@gmail.com
Origin Genesis Pro
-i7 4790K @ 4.5GHz
-GeForce GTX Titan X @ +200 GPU, +300 Memory x2 non-SLI
-32GB RAM
-Windows 10 Professional 64-bit
Originally posted by andybot_cg View PostI have been having crashes as well with lens effects enabled. If I stop the render early, I get a soft crash (a window pops up saying blender not responding. Blender stays open and I can save my work and restart.) No problems if I let the render finish.
I noticed that if I write anything like "\" in the "Image Path" and "Obstacle Path" (even if the option is disabled) the issue is gone.
Could you test it out if this works for you?
architect at oona
Originally posted by leandro_cs View PostEvenly I was getting the same soft crash described above.
[ATTACH=CONFIG]33013[/ATTACH]Originally posted by andybot_cg View Postinteresting! Yes that works.Logan
Omnia Mutantur
logan683@gmail.com
Origin Genesis Pro
-i7 4790K @ 4.5GHz
-32GB RAM
