strange behaviour: auto delete objects
  • strange behaviour: auto delete objects
    Today I've downloaded the last nightly build (2016-08-22) and opened a scene I've worked in middle of July with the nightly of that weeks.
    It seems that, randomly, the scene goes mad and it auto deletes all objects in the scene.
    Anyone else?
    yikes! I haven't updated in a little while, and sounds like it's best to hold off. Been working with an August 11 build, haven't had any issues there.
      confirmed, for me on windows build that hapened too. by the way before autodeleting, properties jumps to world tab.
        Exactly.. the same for me...
          Issue confirmed here too in the build from 2016-08-22(for windows).
          However build from 2016-08-08 is working fine
          architect at oona
            i have got this terminal info if that helps
            Color management: using fallback mode for management
            Read new prefs: /home/tomas/.config/blender/2.77/config/userpref.blend
            found bundled python: /usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/python
            V-Ray For Blender: Parsing plugin descriptions... done [00:00.07]
            Non-zero to use undersampling, 0 otherwise. The value specifies the blur resolution. Value of n means 1/(2^n) initial resolution in each dimension.
            archimesh: added to phytonpath
            archimesh: Imported multifiles
            addon not found: 'object_particle_hair_lab'
            Rock generator settings file found:
            /usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/scripts/addons_contrib/add_mesh_rocks/add_mesh_rocks.xml
            Rock Generator: Numpy not found. Using Python's random.
            ONLINE MATERIAL LIBRARY -- MAJOR PROBLEM:COULD NOT LOCATE ADD-ON INSTALLATION PATH.
            addon not found: 'mesh_snap_utilities_line'
            Exception in module register(): '/usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/scripts/addons_contrib/object_creaprim.py'
            Traceback (most recent call last):
            File "/usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/scripts/modules/addon_utils.py", line 349, in enable
            mod.register()
            File "/usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/scripts/addons_contrib/object_creaprim.py", line 198, in register
            bpy.types.VIEW3D_PT_tools_objectmode.append(panel_ func)
            AttributeError: 'RNA_Types' object has no attribute 'VIEW3D_PT_tools_objectmode'
            measureit: added to phytonpath
            measureit: Imported multifiles
            File "/usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/scripts/modules/addon_utils.py", line 330, in enable
            mod = __import__(module_name)
            File "/home/tomas/.config/blender/2.77/scripts/addons/Vray_Render_Panel-master/__init__.py", line 25, in <module>
            from . RenderPass import RenderPass as RP
            File "/home/tomas/.config/blender/2.77/scripts/addons/Vray_Render_Panel-master/RenderPass/RenderPass.py", line 3, in <module>
            from vb30.plugins.renderchannel import RenderChannelColor
            ImportError: No module named 'vb30.plugins.renderchannel'
            read blend: /home/tomas/Desktop/xr1200xFinalClean vray3.blend
            scripts disabled for "/home/tomas/Desktop/xr1200xFinalClean vray3.blend", skipping 'xr1200x_rigUI.py'
            skipping driver '- (w * Rb) / Rm', automatic scripts are disabled
            skipping driver '(w * Rb) / Rm', automatic scripts are disabled
            skipping driver 'frame * switch', automatic scripts are disabled
            skipping driver 'toggle', automatic scripts are disabled
            skipping driver '(MCloc / R) * dir', automatic scripts are disabled
            skipping driver '-15 * swArmRot', automatic scripts are disabled
            skipping driver '10 * swArmRot', automatic scripts are disabled
            skipping driver 'kickstandRotation/(-1.457)', automatic scripts are disabled
            skipping driver '(- Rb * w) / 2 * pi', automatic scripts are disabled
            skipping driver 'frame * toggle', automatic scripts are disabled
            skipping driver 'toggle * 0.5', automatic scripts are disabled
            skipping driver '0 if bh == 0 and bf ==0 and toggle == 0 else 1', automatic scripts are disabled
            skipping driver 'mat_toggle', automatic scripts are disabled
            V-Ray For Blender: Exporting data for frame 0...
            V-Ray For Blender Error: Scene doesn't have World datablock!
            V-Ray For Blender: Exporting data for frame 0 done [00:00.03]
            info: Loaded "/usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/lib/linux_x64/gcc-4.4/libvraymdl.so"
            info: MDL SDK 2016.1.1, build 261500.9492, 27 Jun 2016, linux-x86-64-gcc4
            info: Loaded library "/usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/lib/linux_x64/gcc-4.4/libvrayfreeimage.so"
            File "/usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/scripts/modules/bpy_types.py", line 673, in draw_ls
            func(self, context)
            File "/usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/2.77/scripts/addons_contrib/io_import_sound_to_anim.py", line 605, in WavFileImport
            self.layout.operator(ImportWavFile.bl_idname, text="Import a wav file", icon='PLUGIN')
            NameError: name 'ImportWavFile' is not defined
            V-Ray For Blender: Exporting data for frame 0 done [00:00.10]
              the last build seems ok... could you check if it's the same for you have experienced this?
                Newest build with more heavy scene crashes. Here is terminal output, sorry if this is messy.
                mod.register()
                read blend: /home/tomas/Desktop/garazo scena35 - Copy.blend
                read blend: /tmp/garazo scena35 - Copy.blend
                ID user decrement error: NTMaterial.243 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@39612e50.001 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@267713a4 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@65347840 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@476272ac (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@4762875e (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@47629c2c (from '[Main]'): 0 <= 1
                ID user decrement error: NTMaterial.244 (from '[Main]'): 0 <= 1
                ID user decrement error: NTMaterial.241 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@5b1f2f40 (from '[Main]'): 0 <= 1
                ID user decrement error: NTMaterial.242 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@396091a4.001 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@3960a538.001 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@3960dffa.001 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@3960f38c.001 (from '[Main]'): 0 <= 1
                ID user decrement error: NTMaterial.245 (from '[Main]'): 0 <= 1
                ID user decrement error: TE.VRayFakeTexture@39611ab8.001 (from '[Main]'): 0 <= 1
                MeasureIt: Cleaning data
                V-Ray For Blender: Exporting data for frame 1...
                V-Ray For Blender: Exporting data for frame 1 done [00:01.12]
                File "/home/tomas/.config/blender/2.77/scripts/addons/planks.py", line 1098, in draw
                if 'reg' in o:
                TypeError: argument of type 'NoneType' is not iterable
                Writing: /tmp/garazo scena35 - Copy.crash.txt
                Warning: Program '/usr/ChaosGroup/Blender 2.77 (With V-Ray Additions)/blender' crashed.
                  if this is useful, with this scene i work in linux and windows operating systems.
                    stugys - looks like there are errors in some other add-ons. Do you still get a crash if you disable other add-ons? I haven't installed a new build since early August, but have been updating the exporter with no troubles.
                      i just deleted one object of the scene, because when i selected it (just plane with mirror material) preview window starts to render mirror material preview, and crashed, after i deleted this miror obect, it works fine, started tes render, so tomorrow will look if this new build works fine
                        looks like it works fine now
                          with newest build autodeleting now happend. Looks like addon for flooring, parquets dont work well
                          terminal output link
                          http://pasteall.org/77696
                            Still broken on latest version for me.
                            • #15
                              just hit CTRL+Z and working fine
