Cube 6x1 camera makes alot of noise
  • Cube 6x1 camera makes alot of noise
    hello, I work long time on one project that requires cube map 6x1 rendering solution, in vray there is a way to make that, but i get verry noisy renders, compered same scene with physical camera ticked on.
    Problem is that cube mape 6x1 mode camera works if physical camera option is off, so I get effect similar like if I set gamma 1 in Globals>Color Mapping> Gamma (normally it is recommended set to 2.2) I think you get the idea.
    My question: can I hope you fix of this or something, because my work must be delivered only this tipe of image form (cube map 6x1)
    For better understanding I place two images, left side physical camera on, the right side physical camera off
Name:	Physicall camera ON and OFF.jpg
    Could you post a scene?
    andrei.izrantcev@chaos.com
    Support Request
      Ok i will send it this afternoon
        If I atatche (pack textures) in to blender file, size becum 52Mb, gmail does not whant to atach to letter, how can i send it to you thi sfile?
          WeTransfer for example
