1) In the Render Elements its not possible to select the material id that I gave the material. I need to render the alpha mask of different materials (like in 3.7).
2) And if you uncheck the "Enable" checkbox the render elements are rendered anyway.
3) In 3.7 you could save and load presets of the multipasses. This should be added here as well.
Thank you.
Thank you.
