Normal + bump map
  • Normal + bump map
    I managed to combine a normal and bump map by putting the normal map into a VrayMtl and then using that as the base shader in a VrayBumpMtl and putting the bump map there. This works, but I was just wondering if this was the best way to achieve this? Is there for example another method that yields faster render times, or would this be the preferred way to combine normal and bump maps?
    there is a container for that. If you look you'll see a normal bump material that has two slots. One for your normal map and one for your bump map. I don't know the speeds difference.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Not sure what you mean. Could you clarify please? I only see one slot in the VRayBumpMtl
      Are you thinking of Max possibly? I think this has 2 slots, but Maya AFAIK only has 1.
        sorry... I am thinking max.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          This is probably the best way to do it; bump mapping and normal mapping are calculated in completely different ways, so there is no simple method to blend them.
