Animation prepass rendering problem
  • Animation prepass rendering problem
    I'm following the tutorial on spot3d to do a moving camera + moving objects render on a file with frames in the negative. So frames from -200 to frames 66.
    I've made the prepass which resulted in the files Longshotz.vrmap and 200 files with the name Longshotz-200 to Longshotz00068 but with no file extension at all. When I set the Irrmap mode to animation ( rendering) then I get this error:
    // Warning: Error loading irradiance map: Error opening file //
    // Error: Could not load irradiance map //
    // Error: This irradiance map cannot be used in animation mode //
    I have set it to open the .vrmap file. So in theory it should work.
    Could the problem be that V-Ray simply is confused about the negative frame values/naming?
    /Bard
    www.hellobard.com
    Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
