vraylightdome with openEXR : image too bright
  • vraylightdome with openEXR : image too bright
    I'm using vray 2 on a new project for the first time
    I'm using a vray domelight with an openexr map for lightiing the scene.
    The problem I have is that the results between vrayRT and the actual vray rendering are totally rendeing : vrayrt preview is overbright and totally blown out.
    Is this a limitation of vrayRT when lighting with an openEXR or am I doing something wrong ?
    Tha openexr image itself is left unchanged (just spherical environment mapping) and the vraylight intensity is set to 1.
    I attached scrrencaps of both vrayRT preview and vray render
    mekene
    Are you using a VRayPhysicalCamera in "Movie" or "Video" mode? There is a known issue with this (already corrected for future builds, but didn't go into the release). Other than that, the dome light with OpenEXR files works fine here.
      I currently I have the same problem. Exr image addition is the same as mine, "Peter Guthrie sky". Not so?
      There any way to solve this?
      Greetings.
      http://www.mediarender.net
        If you send me the scene plus the .exr file to vlado@chaosgroup.com I will be able to tell you more.
          yes indeed kiteman : I am using one of two exrs I bought from peter guthrie.
          I have to say I haven't tried with exrs from others sources, or other formats.
          As for the camera it is a still vrayphysicalcamera
          mekene
            Just did a quick test with some HDR images converted to EXR, but everything seems normal...
              Vlado Ok, I sent a simple scene and
              exr image.
                Ok, I tried opening the EXR through VrayHDRI and not the standard max bitmap map and now it works.
                It's strange because when I was working on previous max versions I always opened the exrs with standard max bitmap and it worked fine. Now i'm on max 2011. Did they change something in the openexr import plugin or what ?
                mekene
                  Yes, there is a new OpenEXR loader in 3ds Max 2011 (written by Cebas).
                    looks like I'll have to stick with vrayhdri loader then
                    mekene
                      Works perfect as theedge said.
                      Vlado anyway I send you the scene to take a look EXR Opened the bitmap with standard max.
                      Regards.
