0.99 reflection problem with shadows
Got a dome with an hdr. Check my shadows on the reflections. Vray 3.40.03.
Doesnt look normal i guess :smile:
Good to know that info. Ye it wouldnt be optimal to disable it. I hope for another fix :slight_smile: thanks a lot!
This is not a bug; it looks like something or someone has been tinkering with your material settings, in particular the “Treat glossy rays as GI” option in the VRayMtl material - it should be set to “Only for GI rays”. For V-Ray 3.5 this option is hidden from the UI (it was meant for debug purposes only), but you can still set it to 1 from MaxScript (the name is “option_traceDiffuseAndGlossy”).
Weird, i didnt do anything :frowning: still want me to upload that scene? ty
Yep.
there u go :slight_smile:
Thanks. It’s because you’ve turned off the “retrace” option in the light cache. V-Ray even prints a warning about this. To fix this issue, either turn on the “retrace” option of the light cache, or as Recon442 suggested, turn off the “use light cache for glossy rays” option. I would recommend the first one (enable the “retrace” option - it’s on by default too).
Thanks alot Vlado! ya i have it off by default on the very low settings i use so i render faster. Its nice to know all those small information though!!
