1.1 or 1.01? errors on max start since upgrading
Just downloaded what I thought was 1.1, but installed its 1.01, is this correct?
Also now I’m getting two errors when starting max 2016
DLL coronautils2015 dlt failed to initialize error 127
and
corona2015.dlr failed to initialize error 127
Edit: I did select clean up previous checkbox on installer
It is known issue that “cleanup previous version” doesn’t work when installing on max 2016. It’s fixed already AFAIK.
You can manually remove those two offending files from your max plugin folder: https://coronarenderer.freshdesk.com/support/solutions/articles/5000530714
I see, and 1.01 is really 1.1?
I think so.
