1.4 - CTexmap element doesn't update in IR mode
As the title says. CTexmap element will respect viewport/orbit changes but will not respect changes to the map or background color in IR mode.
yep, probably no changes to render elements will be picked out (such as changing mode of ID element). Will fix
Great, thanks!
UP! 1.6 have the same problem.
So, I’m running into this again with 1.6 - any way this can be fixed for good in 1.7?
is it fixed?
Do you mean in v3 or v4 dailies? It was still present in v2 if it helps.
if fixed, it would be in v3
Fixed in V3.
