Hi
I’m sorry if that was mentioned earlier - I couldn’t find it.
When you hit “render only elements” button with DR enabled it seems that only main workstation renders “only elements” - all nodes renders much slower as if they were computing all the shading, too.
When using string “bool shading.enable = false” everything works fine on workstation and nodes with DR.
regards
Piotr
