1.4 to 1.5 Glossiness Map LUT
Corona will remap your 1.4 Glossiness Values to 1.5, but not your Glossiness Maps.
This LUT is basically the official Glossiness Value remapper turned into a LUT to work on bitmaps.
Only use this LUT to convert 1.4 maps to 1.5. DO NOT use it on new 1.5 glossiness maps!
You can apply this LUT in Photoshop (32bit Linear) or with a VRayLut map (Corona doesn’t have a LUT map currently)
Almost identical.
Old and New map (47 RGB Brighter in this case)
LUT Curve
Official remapping values that was used to generate this LUT.
Left 1.4 | Right 1.5
1.00 -> 1.00
0.99 -> 0.98
0.98 -> 0.978
0.97 -> 0.973
0.96 -> 0.969
0.95 -> 0.965
0.94 -> 0.962
0.93 -> 0.959
0.92 -> 0.955
0.91 -> 0.952
0.90 -> 0.949
0.89 -> 0.946
0.88 -> 0.943
0.87 -> 0.94
0.86 -> 0.937
0.85 -> 0.934
0.84 -> 0.931
0.83 -> 0.928
0.82 -> 0.924
0.81 -> 0.921
0.80 -> 0.918
0.79 -> 0.915
0.78 -> 0.911
0.77 -> 0.908
0.76 -> 0.905
0.75 -> 0.901
0.74 -> 0.898
0.73 -> 0.894
0.72 -> 0.89
0.71 -> 0.886
0.70 -> 0.882
0.69 -> 0.878
0.68 -> 0.874
0.67 -> 0.87
0.66 -> 0.865
0.65 -> 0.861
0.64 -> 0.856
0.63 -> 0.851
0.62 -> 0.846
0.61 -> 0.841
0.60 -> 0.836
0.59 -> 0.83
0.58 -> 0.825
0.57 -> 0.819
0.56 -> 0.813
0.55 -> 0.806
0.54 -> 0.8
0.53 -> 0.793
0.52 -> 0.786
0.51 -> 0.778
0.50 -> 0.771
0.49 -> 0.763
0.48 -> 0.755
0.47 -> 0.746
0.46 -> 0.737
0.45 -> 0.728
0.44 -> 0.719
0.43 -> 0.709
0.42 -> 0.699
0.41 -> 0.688
0.40 -> 0.677
0.39 -> 0.666
0.38 -> 0.654
0.37 -> 0.642
0.36 -> 0.629
0.35 -> 0.617
0.34 -> 0.603
0.33 -> 0.59
0.32 -> 0.576
0.31 -> 0.562
0.30 -> 0.548
0.29 -> 0.534
0.28 -> 0.519
0.27 -> 0.505
0.26 -> 0.491
0.25 -> 0.477
0.24 -> 0.463
0.23 -> 0.449
0.22 -> 0.437
0.21 -> 0.424
0.20 -> 0.412
0.19 -> 0.401
0.18 -> 0.391
0.17 -> 0.382
0.16 -> 0.374
0.15 -> 0.366
0.14 -> 0.359
0.13 -> 0.354
0.12 -> 0.349
0.11 -> 0.345
0.10 -> 0.342
0.09 -> 0.339
0.08 -> 0.337
0.07 -> 0.336
0.06 -> 0.335
0.05 -> 0.334
0.04 -> 0.334
0.03 -> 0.333
0.02 -> 0.333
0.01 -> 0.333
0.0  -> 0.332
Bonus Guide (For the Cool Cats)
Here is a little guide on how you can keep all that juicy information in your glossiness map after you have applied the LUT.
1.4 clamped everything under 0.3 glossiness, this will help you get that information back.
  • Open your original 1.4 glossiness map.
  • Highpass the original map with 1000 radius.
  • Change the blend mode to “Linear Light” and change Fill to “50%” (You can use lower fill if you think 50% is too much)
  • Paste the new LUT glossiness map bellow the Highpassed layer.
  • Use “Average” on the LUT glossiness map.
We have recovered the clamped information.
Now we’re talking ! You can’t see the big difference because of this shitty little image. But believe me, it’s worth it!
Automate the Process (For the Lazy Cats)
I’ve made a little Photoshop Action that will do everything for you.
You only need to place “Glossiness 1.4 to 1.5.CUBE” in the root of C:
(Like this “C:\Glossiness 1.4 to 1.5.CUBE”)
To load the Action, go into the Action tab and click here
To run the Action, open one of your Glossiness maps and click here
Done!
Glossiness 1.4 to 1.5.CUBE.zip (152 KB)
1.4 to 1.5 Glossiness Photoshop Action.zip (345 KB)
Interesting stuff! Curious if this could be incorporated in Corona converter? Such thing is very needed, but it’s useless unless it can be automated.
Clown should be able to use the table I posted to generate an output curve :smiley:
Taking into account all the cool guides by Dubcat, I think a Corona LUT map would be a reasonable feature request.
That would be great!
I’ve made LUTs from all the functions in Photoshop and CameraRAW. Right now I’m using Photoshops Contrast to adjust my maps inside 3dsMax. VRayLUT doesn’t have opacity. So I have to do it this way. After adjusting the contrast I remap the min/max values to what I want. LUTs give you endless possibilities inside 3dsMax!
Would be amazing to have CoronaLUT with opacity!
Photoshops Contrast has a fixed 128 RGB, while CameraRAW is boosting the mids too.
Great! Let’s hope he’s not too long with new converter version ;]
Well, I can create an output curve but I don’t really see a good “location” to put it to, I mean in the converter. The script doesn’t know which maps are “proper” glossiness maps and which are not.
You know there is already a new version, right?
Well yeah… but does it convert mapped glossiness from 1.4 to latest DB?
Dubcat, I’m sorry for stupid question but what did you mean by “Corona will remap your 1.4 Glossiness Values to 1.5”?
I installed latest daily, then I merged some objects with materials from corona 1.4. PBR mode is disabled in this materials.
If I enable PBR mode, then Corona do nothing with my glossy values, it just enabling PBR and renders my object with “wrong” glossiness. Converter 1.28 doesn’t change glossiness values as well.
So I wrote a little script based on your lut (thanks for that btw) and shared in Corona Goodies.
But I don’t understand what did you mean by “Corona will remap values”
UPD. Ondra told me that Corona remapped glossy before (in some dailies) but now it doesn’t. So question is no longer relevant
Based on dubcats remapping table I wrote a script that converts both glossiness values and textures. 1.4 Materials where the PBR mode is off will be converted to PBR mode on while preserving the glossiness. So 1.4 scenes should look exactly like before in glossiness but with all the benefits from the new PBR mode.
Note: It will not remove any conversion output curves that come from the coronaConverter. It will just add one more output curve on top.
convert_1.4_NonPBR_To_1.5_PBRGlossiness.ms (5.39 KB)
Great! Will it find its way to converter?
yeay finally it comes just right when I planned to write it on my scripting-to-do-list :smiley:
thanx!
edit: big thanx for dubcat too !
Thanks, both of you - Cmpp, here I come )
Thanks, guys It’s a great time-saving for my workflow.
