I’m reporting this as suggested in the error message window, here’s the message:
===== Error(-11) =====
An internal error occured: wxWidgets Assertion failure. Please report this problem to us.
File: ..\..\src\common\wincmn.cpp(3301)
Function: wxWindowBase::CaptureMouse
Condition: !wxMouseCapture::IsInCaptureStack(this)
Message: Recapturing the mouse in the same window?
Before this happened I deleted two images form the image history due to size mismatch while Corona was in precalc stage of a new render.
I’m having this issue trying to go back to 1.4 stable from the 1.5 daily builds. Any way to fully overwrite 1.5 daily? I have tried running the installer, make it uninstall previous, manually delete what was left. nothing helps.
File: ....\src\common\intl.cpp(1607)
Function: wxLocale::GetInfo
Condition: strcmp(setlocale(0, 0), “C”) == 0
Message: You probably called setlocale() directly instead of using wxLocale and now there is a mismatch between C/C++ and Windows locale.
Things are going to break, please only change locale by creating wxLocale objects to avoid this!
Is there some other problem than the message popping up? I mean, are you not able to render, or have any other problems, or the only problem is that the message appears?
