1.47 to 1.5 max camera problem
hey guys,
I have a problem with vray 1.5.
i have a project, completely built in vray 1.47, and it’s something that has to be edited over time (new logos, etc.) so i installed vray 1.5 when it came out, and had no problems, until i had to work in this file again.. somehow the standard max cameras render slightly different views… is this a vray error… or is it just me? and how can it be fixed…?
thanks in advance,
rob
ps. when I open the file vray gives a warning that the file was created with an older version an that the rQMC sampler noise treshold parametermay need to be increased.
hmm.. found the problem, the pixel aspect is off. it has to be 1.067, but somehow (if the original is 1.067, that is) it’s double, so the rendered image is 1.067 times larger (in y) than the original rendered file, wich already whas 1.067.. so I’m a bit puzzled here. even more so by the fact that the file hasn’t changed.. only changes are an update to max (8.3) and to vray…
