Corona Multi Map UI is slow with 3ds Max 2017 sp2. When I open CoronaMultiMap on Slate Material Editor, UI drawing is slow. During opening it, every action is slow. I doubt “sp2”. Please check it.
Max 2017 SP2 here. 28.07 build, I am not experiencing this.
-Is it only happening to you in the newest builds, not in 1.4?
-Is this happening to you only in some specific scene, or in all scenes? (even empty?)
-Can you describe your problem better, or record a short video?
I am only getting a small “preload” for about 1-2 seconds (it looks like it’s refreshing the slots in the multi map) and other than that everything is working smooth.
I said “slow”, but “small preload” or “refreshing lag” is close to my situation. 1.4 is same behavior in all scenes even empty.
You said 1-2 seconds lag, but I have 5-6 seconds lag. Is this normal behavior? I noticed recently this lag. Previously I didn’t notice it. Recent my changes is only SP2. So I doubt it.
We are noticing the same behavior here using Corona 1.5 with 3dsmax2017 SP2. Corona Multimap takes a 10+ seconds to load and the Slate editor pulses frequently while loading.
