1.5 installation
Please forgive me if this is a repeat question, but I have spent time looking for the answer on the forum but must be going blind…!
I have received the software dongle email from Vlado (thanks again), but have not had chance to upgrade until this point. When I go to Vray builds on the support section it liste 1.5RC2 as a demo version. Could someone confirm that this is in fact the full version once i run the file in Vlado’s email.
Thanks for your patience.
Trev
you may have to contact chaos or your in the wrong part AFAIK the demo is different from the reg advanced version.
-dave
If it says demo its the demo.. the file from the email wont change that.
You need to download the full RC2.
You need to log in with your original Username and password for the support section… i.e. if you only create a login there recently all you will see is the demo.
Hi all !
I confirm the problem of Trev…
There is just the demo version, there is nothing in the advanced section.
I’ve tried to relaunch the web connection without anti virus and firewall
but it is still the same.
Don’t understand at all !
Gael
Its not a browser problem.
Is the username that your using to login to the support section the same that you use to get 1.47.03?
Thanks fellas,
Had to login to support section with information used for purchase of Vray.
Trev
Yep, thats exactly what i was getting at. :smile:
:frowning:
No, it doesn’t work for me and I’ve allways used my log from the
very beginning of Vray…
It already hapenned once , but it was du to “Norton”…
Just tried it again without success.
That’s funny !
Gael
You can send us an email to vray@chaosgroup.com so that we can check this here.
