Hi We have 7900x and CPU usage is very low Only 20% making simulation slow. Why cannot phoenix us full power. We are using 3.5 Not sure how to share max file invalid extension
Thank you
Also please add Object mass as animatable feature that way objects can float up or down.
500K is an extremely low resolution. Usually simulation should be at least in the single- or double-digit millions. With 500K each simulation frame starts and stops constantly so that the results are saved to the cache files on the hard disk.
If the forums show you a message that the file you are attaching is an invalid file extension, then just zip the file and it will pass If possible, please attach the Phoenix log file - you can find it under Simulation → Preferences.
