1.5 sp3a max design 2009
Hello all i have a severe issue with sp3a ive installed that ive even tried sp3 for max design 2009 i have the wibu server and key all running and connected. However when i load max and go to indirect illumination and settings tab… they are empty i’ve uninstalled and manually checked to see everythign is uninstalled and then reinstalled and still the issue is happening. Anyone know what is going on ? Im going to revert back to sp2 and hopefulyl this doesnt continue… any help would be greatly appreciated.
You probably did not update the license server to the one from SP3.
Hi Vlado,
When i installed the sp3a I had it install the WIBU key drivers and server and it updated. However when I went back down to SP2 I reinstalled both and it works fine now for sp2 i will try sp3 again when i have some time.
Thanks for your response greatly appreciated!
Kind Regards
Ryan
