Hi ,
got a problem with the noise and a kind of artifacts. It looks like some white spots near the lit places.
There was no problem before upgradeing Corona.
Does anyone have a similar issue and if yes, can you explain what to do to solve it?
Kuba
I notice weird behavior of lights, artifacts (much more noise) as well, I haven’t had time to check everything properly and test it via 1.5 but now that I see this posted around, I guess my eyes weren’t deceiving me. I will post shortly very similar issues, I’m in the middle of a tight project at the moment.
I’ve noticed that putting a portal light, gives me exactly those kind of artifacts (show in the image posted by Marchwiany) in the ceiling, (direct light) while darker areas area clearer than with NO portal light. (this happens on a square room with one wall being completely opened.
I have the same feeling, it looks like 1.6 noise cleanup is longer. Maybe it’s just a feeling. I just reverted back to 1.5.2 to make some tests. I’ll let you know.
can you share the scene privately with us (see my signature)? It looks like a perfect candidate to test new algorithms we are just now creating that shall help a LOT in this case
Edit : ceiling ligths looks strange in 1.5.2 because i was using this in 1.6 :
“Prevent black appearance” for Corona Lights and CoronaLightMtl is a new option that will avoid them showing as black when light constrained by Directionality or an IES profile does not reach the camera.
I just ran a quick test on 3 scenes and all of them behaves differently. One shows roughly the same rays/sample in both 1.5.2 and 1.6 and render slightly faster in 1.6, the other shows about 25% more rays/sample in 1.6, but renders in about the same time and the third one shows about 20% more rays/sample and renders about 10% slower in 1.6 All scenes uses PT+UHD. However those were very short tests, 2-4 minutes each, so results may be not very accurate.
we changed the light sampling algorithm, so more samples generated are not immediately rejected and get traced. This usually lowers noise a lot, but if the scene has heavy occlusion (windows without portals), most of those traced rays might end up being occluded. We are working on including occlusion into the mix for 1.7
So does that mean that corona will eventually know what I need to render, even before I know it myself, and make it for me? Finally a “make art” button.
Is there a chance you have an object / some objects in this scene which are complex geometry with Corona Light mtl applied? The reason I am asking is that I have seen a very similar result in a scene with many lights (light objects) plus some complex geometry with light mtl applied.
I’m having the same problem. Much more noise and more time to clean it.
I have to increase gi to aa to 64 to make it better, but still taking more time than 1.52.
