What the title says. If I have an open IR window and open the Light Lister, I get a crash every time.
Which version of Light Lister are you running, and which version of Max?
With Light Lister v1.3.0 under Max 2017, I have tried several scenes and not been able to reproduce the crash - Light Lister opens fine, and adjusting the parameters in there also works fine.
Thanks!
Tom
Ah. For some reason I had an old light lister, probably since 1.4.
@TomG & Monkeybrother: Is this an official Corona lightlister and where do you get it?
This would be the LightLister that is planned to be included with the Corona Installer, so I would expect that to be in 1.7, if all goes according to plan.
@TomG: And the lightlister v1.3.0 you’re talking about, is…? And where can I find it?
That’s the one due to appear in 1.7 if all goes according to plan - so you can’t find it at the moment, sorry. Just for bug reporting, wanted to know which version was being used that was causing a problem, and testing the internal version we have to see if that is indeed cleared up.
