I’m creating this thread so that bug reports for new DR don’t get buried in unrelated discussions.
Here are the bugs and issues that have been reported so far (daily build 02-24):
Corona Proxy does not appear on slaves
Pass limit does not work correctly with DR
Render sometimes cannot be stopped
New DR does not work with Deadline
Assets are sent to slaves even if they are stored in shared network folder
Scrollbar in DR tab does not work
One issue from previous daily build I didn’t manage to reproduce is that slaves sometimes don’t render at all and send just black images.
Is this still happening in the latest daily build? Do slaves report any error?
slaves seem to be rendering correct number of passes but light mix spinners had no effect and then I tried to change trhe values a few times the whole thing crashed.
tried again, lighmix spinners work fine before DR kicks in, when the slaves start sending the spinners stop, then right at the final pass or near it max crashed again same place near the end of the rendering. First try 200 passes crashed near 200, second 150 passes lower res crashed near 150.
getting alot of these errors on scene that was rendering for the most part under 24/2
dr slave starts then ends max process
2017-03-01 13:03:06 Saving incoming scene to C:/Users/render/AppData/Local/CoronaRenderer/DrData/received_scene_2950344659.max
2017-03-01 13:03:06 Downloaded scene: 851,968 bytes in 0 s
2017-03-01 13:03:09 Forwarded to master: 0errorInternal error. Please report it at https://corona-renderer.com/link/2001:
STOP@C:\Corona\src\CoronaMax/maxApi/SceneCallbacks.h(61)
2017-03-01 13:03:50 Received sampling focus mask
EDIT.
I’m not getting this on my test scenes just my project scenes.
Big difference is proxy trees and plants.
could be down to something odd, it worked til 28/2
1.After some test’s with new Daily build from 2-28 in my animation project i found very specific problem with DR render and animated texture 3dmax .ifl exension file///
Goodbye for animated people from Marlin Studio in our architectural animations
2.After 1.5. hotfix release in all lasted Daily Build’s don;t submit job to deadline 8 via 3dmax submitter script, except with other render’s /Vray,Scanline, and etc./ always Okay/
Problem only with Corona///
The process stop’s on “submitting all frames in One job”///
except that everything is working perfectly:))))
Thanks for job!!!
I am sure he can fix it no worries.
Are you still using those? I think they are as old as my career, 20 years? I never used them do they look good?
I installed the latest build today and I still notice the problem of stopping the DR rendering process manually. Every time I press STOP at the master PC one of the slaves continues to render and the process goes on infinitely so I have to save manually the final image…
In last Daily from 2017-03-01 there is no problem with .ifl sequences and XREF files//
thanks very much for fix!!!
But there is still a problem with Deadline submitter:(
Collecting extra data from slaves doesn’t still work!!! The main PC has the session open for 15hrs collecting the last data from the server which never arrived… Had to close manually the DR process.
