Hi chaps,
I have noticed that Corona interactive render 1.7 is slower than 1.6, is it just me or what?
Best
Dan
Hi chaps,
Best
Dan
Can you show us some video screen-capture of file running inside the two versions?
And can you give us more info?
me too !!!
1.7.2 is slower than 1.6.3.
is impossible for me use 1.7, is TOO SLOW ( i have a dual xeno e5 2698v4)
now I reinstalled the old 1.6.3
i opened this topic : https://forum.corona-renderer.com/ corona 1.7 interactive render problem (SLOW)
and one month ago I opened a ticket on Corona Renderer Helpdesk, where i upload scene and screenshot,
but nothing happened…
I hope this is not the prelude to what will happen to corona render after the acquisition of chaos group. !!!
I sent you this message and never heard back:
“Meanwhile, if you would like to check this, there is one more idea: go to system tab > system settings and change the “# of threads override” from the default -1 to -2, -3, or -4. You can also try with higher values.”
So does it change anything?
How could this be related to Chaos Group?
no, nothing,
Thanks for checking.
Also the same for me here, I revert back to 1.6 and significantly quicker.
I also discovered that instanced group of lights were not displaying however they worked perfectly once I reverted back to 1.6.
What is your processor model?
Can you explain this? It sounds like a different issue.
Hi Maru,
Sorry for delay reply, I am using a dual Xeon E5-267W 3.1GHz. on Win 7.
Yes you are correct the grouped lighting which was mirrored but not rendering in a refreshed IR view is a separate issue.
Cheers
There were some fixes regarding IR in our latest daily build. Could you test it? https://coronarenderer.freshdesk.com/support/solutions/articles/5000570015
It would be best if you could describe it well and report here Renderer for architectural visualization - Corona | Chaos
dcode:
i have tested the latest daily build but
the problem is still exist ![]()
