100% red distributed render passes
All exr dumps recieved from slaves are 100% red
We’re running max 2015, newest version of corona 1.12 - win10 on main pc, and win7 professional on slaves.
Everything works fine with the pc’s who are running on win7 and max 2014.
None of the textures are missing, everything is mapped to a network folder.
What is wrong?
Here’s a exr dump from one of the slaves (converted to .png)
Are you using Corona bitmap?
Shouldn’t be a problem with the bitmaps, everything renders just fine until I start recieving the passes from the slaves. All bitmaps are located on a shared network folder, so the paths shouldn’t be a problem either.
:frowning:
Are you using this red color anywhere? Env color in 3ds max enviro, Corona enviro, color tint, fog…?
That does not answer the question… Corona bitmap now renders red if the bitmap is not found, so that could be the case
There’s no red in the scene.
I also tried rendering a simple scene with bitmaps from the same network folder, and it worked fine.
I had this problem when one rendernode had a newer Corona version than the others. Then this node introduced red stripes into the image.
Do all your PCs have the same version?
All computers are running the same version of corona :S
And DrServer too? Which version is that?
Same version on all
