10m/s wind not having much of an effect.
I’ve added a PlainForce with a strength of 10m/s (I assume it’s per second) and it’s not doing much at all. Is plainforce the right object?
https://www.dropbox.com/s/jqny8398k7…3_001.max?dl=0
edit: Warning: Don’t try to render, it will take forever.
Hey,
Here’s what units the plain force is in :slight_smile: Chaos Docs
Cheers!
In general, unless you are certain that there is a bug or something you’ll need programming help with, just a couple of shots with the settings and how the scene looks would be enough so we can help you set up your scene :slight_smile:
I’ve tested the attached scene and noticed that there are active Turbulence, Vorticity, Randomize, Source Noise - all these options add different forces/velocities and it’s hard to say what’s going on. And the Plain Force’s Drag parameter was 0.1 which is not enough to overwhelm all velocities (from docs: Drag | drag ? Specifies a value between 0 and 1 to determine how much of the existing velocity will be negated over the period of 1 second. ). That’s why I begin to reduce and disable some of this options until Plain Force became visible (@Strength=1000 and Drag=0.7). I’m attaching the scene back again to see the result and you can play with the settings to achieve the desired result or just experiment with them.
Fire3_001_Max2015.zip (56.5 KB)
