110% vfb
Hello there,
so I have to set the production render to 110% to get my final resolution.
Why isnt it 100%? Or is there something I dont get?
Hello @folklore ,
Can you please elaborate some more on your query? Are you referring to the new test resolution function in the VFB and why there isn’t a 100% option there? If that is the case, please note that if the test resolution is disabled, the image will be rendered at 100% of the resolution, set in the render settings. By enabling the option, you can change the resolution directly from the VFB without the need of changing any render settings for test purposes. I hope this answers your question.
thank you. wasnt aware of that I could disable it.
