Looks like they reached a new plateau! ![]()
Great images ![]()
good one! yeah I think they did.
absolutely great ! in the first render there are some artifacts (straight lines). I didn’t know they provide Lidar scans ![]()
Thank you, yes there are some artifacts that I have already removed, that one was from a particular mask, these are straight from the Frame buffer no photoshoping, the 4k renders help to spot areas for improvement.
Very nice, beats using Google Earth mess, too bad it’s only Northern USA, I could use a European version.
Yes, I wish would be available for Europe and some other countries, I also looked for Australian Geological survey since I may be starting a terraforming Sci-Fi film shot there, would come in handy.
Beautiful works on your site Ashley, well done.
Very cool! I have been pulling 2D maps from them for my hikes. I’ll take a peek at these photos.
Yeah that’s a good idea, I’ve been there many times off roading with my FJ cruiser and you can find interesting features to visit from looking at these maps , specially in 3D.
Could you possibly provide some info on where to specifically download these LIDAR scans? The USGS site is kind of bewildering. Also any info on how you go about importing the data and using it in Max/Vray. I have had a lot of frustration trying to get LIDAR point clouds turned into usable meshes and etc. Thanks in advance for any direction you may be able to provide on this!
You have many trips in Monument Valley? I live about 4 hours away in western CO. We spend a lot of time in the canyon country.
I’m out of internet right now but will pull some info for you a bit later. There’s no point cloud data used here , just GeoTiff texture from the Lidar . More later.
Thank you sir!
Thanks very much! All that is new to me but I will give a go as soon as time allows and see if I can generate something usable.
It sounds like we may share an interest and fascination with the canyon country and high desert. Here is a link to some small photo collections, 10-15 photos each, taken from remote areas around the Colorado plateau including Capitol Reef, Bears Ears, Canyonlands, Zion, Grand Staircase/Escalante, Grand Canyon and more.
https://www.openrangeimaging.com/adventure.html
Your work shown on the artstation link is very impressive, you are very accomplished!
Thanks again!
Thanks Mark.
Those trails you did are great, I’ve been to a few of them , best way to appreciate all that beauty. I gotta go back there again I hope.
Thanks for sharing your adventure photos.
Coincidentally I just got a job in that calls for a fly out to space, from a canyon based scenario.
I have tried and failed to get those same maps…only partial ones seem to be available
after many attempts, so I’ve ended up with not enough which is very annoying.
It’s possible that I’m missing some step in the process but it appears simple, so not sure what’s going on tbh.
In which case would it be possible for you to upload them somewhere please, or possibly you have the download links?, as it looks like the ideal coverage to be able to
switch to a zoom hack to end up at planet earth.
I’m using GAEA for this at the moment to try to recreate something similar, though I’m new to it so not sure whether it’s possible to output such a large joined up area.
I’ll understand if it’s problematic for any reason, so don’t feel obliged ![]()
That is always a complicated thing to pull it off, first thing is find an area that has good Lidar coverage,(Monument Valley is missing a large area) not the entire US is done with Lidar yet, then from the same area you can find a larger terrain coverage from the SRTM 1 arc or 30 sec arc and then an even larger terrain map made from scratch in Gaea. Transitioning from close up to very wide is the hardest part, first hiding the seems and texture resolution for each terrain patch, aside from that some cleaver placed clouds and the natural motion blur might help disguising some mismatches. For extreme close up out of the canyon I would go with megascans rock formations or buy any available ones well made online, there are many on Turbosquid.
I’ve never done one quite like this so definitely a learning curve will be necessary here( this is also very time consuming for a single artist as you might now already)…a shot I did a while ago of Millennium Falcon and a large terrain escape in World Machine here. https://vimeo.com/222100867?embedded=true&source=vimeo\_logo&owner=43539931
Good luck
Yeah I already have a scene which will work using Megascans…looks great for little effort, so it’s just a matter of transitioning from that to a larger landscape.
I have canyon made up in GAEA and so I guess now I’m planning to incorporate the megascans stuff
into the GAEA scene, with possibly a secondary GAEA terrain to blend to/from, then work that into a satellite map of Utah.
They’ll not have a movie budget so it’s likely they will have to be satisfied with the best I can do with commonly available data and some tricks.
In theory it’ll work but we shall see…I’m only a day into trying to sort it all out but so far it’s all looking very achievable ![]()
So I got the Lidar data into both Gaea and Max, using the same basic maps as you have used.
I also discovered I don’t need to mess with exposure for them to work, which wasn’t giving the correct result for me.
Not sure how you managed the result without the banding I got.
Gaea can clamp them and max just need disp set to landscape and a very small value.
Do you think it’s the same as you achieved in terms of detail?
My next small hurdle is getting maps to work. I’d appreciate any quickstart advice you can offer.
I know you mentioned extracting masks from Gaea/W Machine but I’m not entirly sure which I need to achieve a somewhat similar look to what you have managed.
I assume it’s the slope/soil etc but are you using just those as mask for completely new shaders…Megascans or whatever…or are you using the satmaps?
I have experimented with them but the output is as the Gaea preview, showing horrible stretching on the verticals, which I think is a common issue.
The problem I can see with masks is that by using landscape displacement I can only have 1 uvw channel…can’t see a way around that…
The attached one is experimenting with decals, which could come in handy if I can’t figure it out ![]()
Oh Wow! it’s cool to see someone else tackling the same file.
Its hard to say if it is pulling out the same details but it looks like it is, and it should with Max and Vray.I found that it was easier to do 2D displacement and not use edge length in Normal displacement, it didn’t affect rendering time and just gave me
all detail contained in the map.( but that is for a still image not animation)
I did get a similar gash seen in your image at the left bottom and that was because when I aligned in Photoshop the 4 maps , one quadrant was misaligned a pixel or too.Is that what you referring as banding?
Concerning the map extractions from Gaea, the masks, maybe you don’t need as many as I did but the essential ones, lets start bottom to upper layers, maybe start with the dry river wash if that is going to be important, then a mask for the desert floor,then a mask for 45 degree of the slope sediments, next mask is the 90 degree cliff walls and one more for the top of the mesas.
Doing a texture map in Gaea , even exporting at 16K won’t be enough to be close to the surface that’s why tiling of the soil for each shader is crucial.
Also remember that you need a Vray triplanar node to project the cliff texture and a Normal map into the displaced 90 degree cliffs because the Lidar cannot detect details from 90 degree terrain so those features are lost, just becomes some straight vertical lines.
About the Uvs, I also only used one UV for the close terrain and the larger mesh had also only one UV, …Udims would take too much time to texture and set it plus all additional masks…yeah don’t go there.
I did not have the chance to play with the new Decal feature yet.
Hope that helps a bit more, I could provide you some of my maps but they might not line up with your set up. The tillable textures I could put on dropbox I think.
I did a flying animation low thru the landscape and sent it to Vray Cloud service but I rushed my camera animation and I wasn’t happy at the end and moved on to other projects.
