12k render dont working
Hi Corona Team,
i have a problem here.
We are trying to render an image with 12k resolution, this file has a lot of geometries and spend a lot of RAM.
We bought a new computer with 128gb of RAM and 2 processors to save our render times but it dont solve this problem.
When the render starts, it consume around half of memory but the processors works on full capacity and stop on the initial passes. the hour count shows aways the same estimated time and the time used is aways growing up.
How can we fix this?
What model of processors are you using?
its attached
we’re using Corona 1.3
I am not sure if I understand everything.
Corona is a progressive renderer, which means that it will render infinitely unless you set a pass or time limit - are you aware of that?
See: https://coronarenderer.freshdesk.com/support/solutions/articles/5000515590
Is the rendering progressing? Is the VFB refreshing - showing the image becoming progressively better?
I’m sorry. I think I explained it wrong. Let me try that again.
When I fire up the render in 12k it takes quite a lot of time to start rendering due to the displacement calculations. That’s OK and expected. It eats up quite a bit of the available RAM that I have in the system, but we don’t get any messages saying that we are runnning out of resources whatsoever.
Then it starts to render as expected but suddenly it stops refining the image. The last time we tried, it stopped on the 8th pass (from 120). Then even though the processors were fully in use, the elapsed time continues to run while the remainingn time freezes and we don’t go any further.
We never had this sort of problem before.
Are you also experiencing any freezes or crashes with this? Are you able to click “cancel” in the rendering dialog and the rendering stops, or do you have to force close Max?
Maybe it’s just VFB that stops updating? Did you try to save image and see if it’s more refined than it shows in VFB?
Just out of curiosity to see if this helps, can you try to render it in Bucket mode and see how it behaves?
Try with 17 samples per pass, 7 passes.
Cheers!
Actually I had this problem when using displacement with 1px in the setup on 4K images. It takes some time until the process stops after you hit “stop” or “cancel”
I guess it take quite a lot of time to stop processing at 12K.
Never considered this as an issue.
Tried rendering it in bucket mode, using the settings you suggested.
It started quite well and within one hour it started rendering. I could see that some of the small areas were not rendering, producing these black blocks spreaded out in the image. Got here this morning to see the render and once more the remaining hours was frozen while the elapsed kept running so it seems like the same problem happened again. (see screenshot attached)
I just clicked the CANCEL button but 3dsmax haven’t stopped the render yet. I will wait a few more minutes before trying to force quit it. I will update this thread soon.
Just a note: render window shows only 1,3GB memory consumption (?). Strange.
And the CANCEL didn’t work. The funny thing is that when I forced quit the scene via Task Manager, 3ds max asked me if I wanted to save the file (?). Weird.
Any thoughts? Maru?
  1. Is this also happening if you render a lower-resolution image?
  2. Can you see if lowering “# of threads” in performance settings changes anything? (to -1 or -2, make sure you are not changing the # of threads for interactive rendering)
  3. Please go to task manager and check:
    -what is the process priority of 3dsmax.exe?
    -are you able to change affinity of 3dsmax.exe?
This is an old topic, but if any of the issues listed here are still valid, please check for improvement in Corona 1.6:
If the issues appear again, please be sure to notify us about it via support@corona-renderer.com , or by logging the issue on Mantis: Renderer for architectural visualization - Corona | Chaos
