1st test with corona
Hi everyone,
This is an old project of mine, and seeing as it is very simple I thought it would be a nice easy start for trying out corona. Each one got to about 200 samples i think or passes, or whatever its called :wink: and took about 2 hrs.
Original set done with vray here: archive — PETER GUTHRIE
So… how do I get access to nightlies then!
Peter
I was waiting on your “first” post here hehe! As usual, very nice starters. Hope to see more images from you soon.
How do you feel working with corona comparing to Vray ?
I’m quite sure it can be faster, indeed I hope it can! I used PT + HD.
I’ve only had 1 day playing about with corona so far, so most settings still a bit of a mystery which is partly why I’ve asked Juraj to do a tips & tricks type post on my blog so that I and others can get up to speed.
will check out the alpha builds section, thanks!
Why would you classify this as “simple scenario” ? Seems to be pretty lot of GI work. And I think all materials are specular, even the matte paint, as it does look so from last image.
It could be pretty high RGB value for white, though I can’t know.
Regarding settings, there is no big magic behind imo. Playing with PT samples or with MSI/HD does the trick but, for the still images, changing those settings doesnt have drastical impact on speed/quality ratio.
For me, MSI parameter is most important for interior renderings.
Also, you can cover openings with planes with CoronaPortalMLT.
Here is my pretty simple test, how portals can speed up the rendering : Corona portal test - Corona for 3ds Max :: General - Chaos Forum
Here is Peter… waoooo, what some great artists here. I stay !
Yeah probably every material has glossiness, and GI wise i dont think its the easiest scene to light.
Let me check if I had any directionality on the IES lights.. and what my white walls were set to.
re: portals, I thought I read somewhere that they werent always an advantage… ? I am using a HDRi sky.
happy to try one render with and one without to see if it speeds it up.
Portals should help with scenarios like you have here, where you need to “push all light thru that hole”.
I have heard that they can slow down renderings in scenes with big openings, but i have never noticed any slowdown and im using portals almost in all my scenes.
does the normal of the quad matter? ie. facing in or out?
Keymaster (dev) told me that no, but im always face-in.
No. Rules for portals currently are:
  1. no double portals (2 layers of portals in the same window)
  2. keep them as low-poly as possible
Restriction 2 was already removed in the unstable builds.
Nice to have you on board Peter :smiley:
Looks nice Peter,
I remember the originals of this set well. Always liked the contrast and balance you managed with the warm/cool lighting. Looking forward to your future corona posts.
Cheers
I did a whole load of tests, but nothing really conclusive.
  • I think the main problem may be the IES lights, has there been progress in this area in the daily builds?
  • changing light samples multiplier from 2 to 5 made the most noticeable improvement for the same rendertime.
  • adding a portal made no noticeable difference.
  • in the original set I had the MSI at 400. Changing to 100 was an OK trade-off. Dropping to 20 made the image noticeably darker.
p.s. thanks for the warm welcome!
The daily builds have support for the standard 3dsmax lights, so you could use a photometric light with IES profile, that generates zero noise. This is currently faster than proper area lights with IES, because I haven’t gotten to sampling directional light yet. And IES is in its core nothing else, than directional light.
thanks Keymaster and Rawalanche, will try daily build as soon as I build up the courage.
Just a quick question re: HD Cache, are there settings there I could be tweaking or should I leave them as default?
exactly what I needed, thanks!
Welcome aboard Peter!
pretty interesting tests, the lighting is amazing, thanks corona for make this
so easy, with a good understanding of lighting/camera/photography we can reach
very good results.
As I always say, at the end of the day what really matter is the image.
Hope see new stuffs from you my friend,
Cheers
Fernando
