2.1.3.1901 can't recording camera rotate
I can’t record just camera rotate at same position.
Now the video looks weird.
This functionality will be added in future releases. Right now, the velocity along the path is constant, independent from sharp movements.
I do like the new timeline and also ran into the same issue.
I really like animation improvements and new features such as adding multiple keyframes and save/load path option.
New editing keyframe(camera) window is great, and I could suggest to incorporate “add keyframe” button into this window, as well, and then entire animation could be created in this editing window.
Also - if selecting already created keyframes (cameras) could be enabled in this window - it could really become future tool for entire animation creating/editing in enscape.
You can also press K to add a new keyframe.
Getting Enscape to just pull from SketchUp’s cameras would be great.
@ValeroStudio Do I interpret your suggestion, as to create a video path that has sketchup cameras as keyframes? How do you imagine to select the cameras to use and their order? With camera synchronization enabled, you can switch to the cameras you like and add a keyframe there. It’s a few more clicks, but already possible.
