2.2 update issues.
Hi guys, it’s been a long time without using vray for rhino.
I have switched to max in the last year since I have been working as an employee.
I use it every now and then at home whenever an update comes out.
Today I got a couple of hours to test the latest update, some things I noticed. (Cpu mode)
- Real time render does not update correctly when I use areal perspective or env fog, i need to stop and restart. (Update: turning off and back on any light solves the problem without restarting)
- ram unloading is really slow, very annoying.
I understand this happens when I use 2d displacement on very large areas and with large textures (8k).
know that a high consumption of ram is expected, but I don’t understand why it takes 15 minutes to stop the render.
I will add any other problems in this post as soon as I find someone
I am still experiencing rhino freeze during autosave if I am using the real time rendering…
Hi @Grigio18
Apologies for the late reply!
Could you please follow up on the PM I have sent you?
