2 glass materials on one object
Hi
I have one problem when i render one object with two different glassmaterials added
for an example: i have on normal drink glas and i want the half ( from bottom to the middle of the glas ) to be transparent and the rest to be with a color just added with fog color.
if i do so the glas will be only transparent, but if i detach the 2 section and add the 2 different glas materials separate it is working.
this is a problem, anyone that know what could be wrong?
if i use 3ds max 8 with vray 1.5 for 3ds max 8 it is working but unfortunantly i must use 3ds max 9 with vray 1.5 for 3ds max 9 and with 9 it does not working. (bug?)
/Linda
/Linda
This is a bug in RC3; it is already corrected for RC4.
Ok thank you Vlado, now i know.
/Linda
