2-point perspective issue
Hello!
Rhino 6, Enscape 2.7.1. The preview window displays 2-point-perspective correctly, but when I render to file, it results in a 3-point perspective.
Did I miss a switch, or is there a bug?
Edit: this is only the case when synchronizing in turned on.
Thanks a lot!
This is by design, since Enscape takes over what you defined in the settings, or also in the settings of each view - make sure to simply setup the Projection of your choice in the Visual Settings and then render as usual. :slight_smile:
