It seems that V-Ray renders an offset viewport when the Rhino viewport is set to “2 Point Perspective.” Anyone know how to correct this? The standard Rhino renderer is fine…looks like this is specfic to V-Ray.
Rhino 5 / 64-bit Windows installation.
Thanks,
Ron
Hello Ron-
You may have to post some images to show us what you are talking about. The only thing that I can think could be wrong is that the view aspect being rendered does not match the Rhino viewport. You can set the view aspect ratio to match the viewport in the rendering options under the Output rollout by selecting the “Get View Aspect” button. The rendered two point perspective should match the Rhino viewport.
Corey
Hi there!
I exactly know what you’re talking about, since I’ve got the same problem. I hope that anybody reads this and can help. I’ve attached 3 files to this post: The first one shows a rendering with standard settings and a normal perspective. The second one shows the viewport of the 2 point perspective. And the third one the resulted rendering. You can clearly see the offset problem that rwitte tried to explain.
Any suggestions?
Best
Toni
Hi Toni and Ron,
Looks like the problem appears when set new camera locations, can i try your simple scene?
Hi Marko,
This bug is already added to our bug tracking system and wait to be fixed.
I hope this will be fixed soon.
