2 renders same settings, different sky
I’ve just done these two renders (No I’m not a render master). The only thing different is the brick is white in the first and grey in the second. When I was putting it together in photoshop I noticed the difference in the sky. Exact same settings. Exposure set to auto and white balance set to 6500k. Any ideas on this?
disable auto-exposure and set the value manually.
you can find the auto-exposure value by clicking on the double circular arrow to the right of “Auto Values”.
Hey @patrick_anderson ,
Please refer to the following forum thread on the matter: V-ray Interactive lighting vs actual render not the same - Issues - Chaos Forum
If you’re not using the Auto WB/EV options, do forward us the project via our contact form so we can investigate further. Much appreciated!
