2 sided glass Is it possible?
Hi to every one.
I’m dealing with this 2 material in ONE material (see image below to understand)
I was wondering If it’s possible to do it only with one polysurface or I have to split in one polysurface (Clear glass) and then, separately, a surface offset with the Frosted white glass.
Thanks a Lot.
Re: 2 sided glass Is it possible?
One material per object, can’t apply two materials to one object.
… and than use a map with black and white/grey areas to control the blurryness of the reflection/refraction. I don’t tried it, but could work.
Thanks both of you ! I Will try
Zooropa
Such a very amazing link!
